Any way that prompt a pull down menu when click a cell of table?
Hello guys,
Thanks in advance for your reading...
 Enter characters for each cell in table is difficult,  i want to program to show a pull down menu when click the cell in the table, so i can easy to input the characters by click the item on the popup menu.
Thanks, Steven
Message 1 of 10
(4,651 Views)
There no direct way of "embedding" a control inside a table. As mentioned in this discussion, you can try to use right-click popup menus (by creating a custom run-time menu), detect where the mouse was clicked, and then entering the text into the table programmatically. An alternative solution is to use an ActiveX table control that's designed for this purpose.
Message 2 of 10
(4,633 Views)
Hello, thanks for you attention,
I am looking for a ActiveX table like you said, can you tell me where can i get it?
Thanks, Steven
Message 3 of 10
(4,615 Views)
hi
download this application http://forums.ni.com/attachments/ni/170/189313/1/ModbusDatalogger%20Demo.zip
Extract and run the application go to config screen and see the table which can be configured using dropdown boxes are you looking something like this?
if its the same let me know. i can post the code
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
Message 4 of 10
(4,594 Views)
Hi Tushar,
Great & neat work !
I wish to learn more about embedding rings in tables for my application. So, can U pl post Ur code saved for LV 7.1 for me too... ?
I wonder about the colours & neatness of Ur UIs [ VIs ], of course !
It'll be of great help if U can post the code here.
Mail me across parthabe@rediffmail.com. I'm from  Chennai, India.
Regards & Thanks.
- Partha ( CLD until Oct 2027 🙂 )
Message 5 of 10
(4,586 Views)
Hello Thshar,
Very good, that is what i want, If you can post the code for me is highly appreciated. Thank you!
My email: steven.huang@wongswec.com
Message 6 of 10
(4,572 Views)
I'm just replying to know when the example code it's posted. It's a good idea and I also wanna know.
Software developer
www.mcm-electronics.com
PORTUGAL
Message 7 of 10
(4,546 Views)
Here is the example code
Tushar Jambhekar
Message 8 of 10
(4,518 Views)
Tushar,
FYI: You need to post the actual code. The "Drop Down Table" subVI that does all the work was saved without a block diagram, and hence cannot be opened in LabVIEW 8.2, or on other platforms.
Message 9 of 10
(4,504 Views)
Thank you, Tushar
I can not open it with LabView 82, it prompt that " VI revision 8.0 can't be convered to current revision 8.2 because it has not block diagram", Would you please post full code for us?
Thanks in advance, Steven
Message 10 of 10
(4,480 Views)
