Any way to change the font size for a table?
The table's property page does not let me change the font size for the table. Is there any way around this? I've tried playing around with control references and the 'To more generic/specific' class controls, but I haven't been able to make it work.
Also, if there is a way to set the active cell range and change only part of a table, that would be even better.
Message 1 of 8
(7,869 Views)
If you are trying to change the font size of text in a single cell, click the text then select the font or just press CTRL +. Even with no text in the cell it will change.
This works for an indicator as well as a control
goldie
Message 2 of 8
(7,860 Views)
That's what I'm currently doing. It isn't very efficient when the table is about 100 cells
Message 3 of 8
(7,853 Views)
If you want to change all 100 cells then click on the table and then apply the font change from there. Other than that you can dynamically change the height/width of the active cell row with a property node.
goldie
Message 4 of 8
(7,850 Views)
What tjazx9r wants to do is dynamically change the font in the table. There is no such property. The property exists for strings under Text.font.size
I would like to do the same as I want to adjust the font in the table while running the VI as an executable. Any answers?
Message 5 of 8
(7,760 Views)
While the table cells in older LabVIEW versions don't have font properties, if the table is only used as display and not as an entry element then the multicolumn listbox would be a good control. It does allow changing the font through property nodes.
Otherwise upgrading to LabVIEW 8 will give you font properties for the table cell.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 6 of 8
(7,755 Views)
Thanks Rolph. I did find KB ID# 29A9QMDM that indicates LV 8 as the only answer. I like your work around method and actually tried it out before joining this thread. Perhaps you see something that I don't, because after checking numerous times I stll can't find a property or way to change the font size programmatically, even for the multicolumn listbox.
Can you point out what you see that allows changing the font size in teh multicolumn lisbox?
 I'm only looking to change all fonts at one time, not on a cell to cell basis. Changing font color would also be nice. Hope there is a clever way.
Thanks a dozen.
Message 7 of 8
(7,750 Views)
Thanks a dozen.
Hmm, this is a disturbing thing. I could have sworn that I have done something like that in the past. But I must have something messed up such as only changing the background or foreground color instead of the entire font setting. I apologoze for this kind of misinformation.
Rolf Kalbermatter
Message 8 of 8
(7,747 Views)
