Any way to make the x and y axis of XY graphs in labview to be equal in scale as well as axis span?
Hi there! Is there any way to make the x and y axis of XY graphs in labview to be equal in scale so that (for example) the plotted points of a circle will be plotted as a circle on the screen? At the moment, there doesn't seem to be any setting to provide equal-axis plots, so that instead of seeing the plotted points of a circle, you can get an ellipse because there's no way to fix the axis to give 1:1 aspect ratio. In Matlab, you have axis('equal') or axis('square') commands (or something like that to get what I need. Thanks very much for any help.
(5,712 Views)
Create a property node and select
Plot Area>>>Size
Write the same value to both cluster elements.
Should give you a square.
Ben
(5,712 Views)
Thanks for this help Ben. I tried it, and it worked well for what I need.
(5,712 Views)
Dear Ben,
I noticed this is an old post but I'm asking anyway.
I tried this but it makes the plot size squate, hoever the X  scale factor if different than the Y scale factor which makes circles look as ellipses.
How did you manage this?
Marius
(5,206 Views)
Hi Marius,
use some simple math to adapt X or Y axis settings to your scaling factor…
(5,203 Views)
Yes, I just did it like this. I had to consider graph width, height, X scale and Y scale.
Initially I automatically adjusted the height of the graph but seem akward when the plot was changing size a lot, so I changed to automatically adjusting  Y scale instead.
I asked about Ben's solution it seems like a easy one moreover I don't understand how somebody already confirmed it works. I have many graphs which I all want scales as square. This solution works but it doesn't seem elegant to have it in a lot of VIs each of them with 3 to 7 graphs.
I'm stil vondering if I'll ever see a simple solution (ticking a option).
Marius
(5,196 Views)
