Any way to prevent update to enum constant size on BD after edit?
Forgive me if there is an obvious fix to this. I hope my attached pics are clear.
Is there any way to keep this from happening when I add a new value to a type definition enumeration?
I find it really annoying that adding a value or changing the text in an enumeration would show up in all my Block Diagrams being
less readable.
(2,867 Views)
This is "fixed" in LabVIEW 2010, I think.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,862 Views)
Actually its not.
I was hoping someone might have found a way to work around this annoyance other than to use 4 letter enum text fields.
No worries though. While it is annoying to have your Bdiagrams messed each time you change somethjing in the type definition it certainly is not a show stopper.
(2,844 Views)
To avoid missing up the BD each time, as we are using some typedef'd clusters of enums that take up a certain amount of space on the diagram, I have taken to encapsulating them in a vi, so that at least from an aesthetic point of view they: 1) don't take up too much space, 2) don't suddenly change their shape due to some small edit of the typedef.
Putnam
LabVIEW Champion
(2,828 Views)
