Any way to set file/folder attributes in PDA?
The subject says it all ... I have done some research and my initial instinct in to say no - there is no way of doing this under PDA module, but I thought I would put it out to the community and see if anyone knows anything I can't seem to find.  Is there any way to set file or folder attributes using PDA module?  Thanks in advance for any help/insight.
Greycat
(4,385 Views)
bump ... NI can you confirm this?
Greycat
(4,376 Views)
Hello Greycat,
I looked into this issue on my side and could not find any specific VI that will do this for you. I would suggest using the Call Library function node to call a third party Dll to get this task done.
Hope this helps,
Chetan k
Application Engineer
(4,364 Views)
Thanks CKap ... that s what I was looking for ..
Greycat
(4,361 Views)
