Hai...
I am using a ring control in my application.
And i have stuffed data into that from a 1D arry.
I have initialised its ring text to the first element of the array.
Now the problem is,if the array is having 10 elements ,the ring will contain 10 elements but one of the elements
is appearing twice there by missing one actual data.
If the ring text is "?sample" sample will be appearing as ring text andas last element of the ring.
and one of them is having a check mark.
I havent faced such a problem before and i am not much experienced in labview.
Then one more thing.When i click the ring control,it pops down.How do i display the elements as popped up?
How to include scroll bars to ring?
Thanks...
