Anybody knows how to read the data size through my network card
Anybody knows how to read the data size through my network card, includes sent data size and received size. who knows ? thanks in advance.
Message 1 of 9
(3,980 Views)
Hi Gilbert,
what do you want to do? Your question is incomplete, lacks any detail. What do you have already? Show us your code and we might show you a solution.
Ton
My LabVIEW Ideas
Message 2 of 9
(3,970 Views)
        Thanks, I want to make a program with labVIEW, the program can read all the data size(received ant sent)  through local network card (LAN), I don't know how to do this, the basic function is similar with " Local area connection status".
Message 3 of 9
(3,966 Views)
Hello Gilbert,
I'm not familiar with this function, but for a network connection there are several options, which protocol do you use?
Ton
My LabVIEW Ideas
Message 4 of 9
(3,961 Views)
         Thanks, I want to get the data size through LAN back, and display for user, how many data in and out !
See enclosed !
Message 5 of 9
(3,961 Views)
Whow,
that is deep down Windows. I *think* that you have to do a win32.dll call, but i'm not sure.
sorry,
Ton
My LabVIEW Ideas
Message 6 of 9
(3,956 Views)
Maybe a .vbs script file will work. This reads raw performance counter data. You may need to read the initial values when you start labview and then subtract them from the current readings.
http://www.microsoft.com/technet/scriptcenter/scripts/network/monitor/nwmovb19.mspx
The results from running this:
Computer: HPA1230N
BytesReceivedPersec: 64047717
BytesSentPersec: 7878006
BytesTotalPersec: 71925723
Caption:
CurrentBandwidth: 100000000
Description:
Frequency_Object: 0
Frequency_PerfTime: 3579545
Frequency_Sys100NS: 10000000
Name: Realtek RTL8139_810x Family Fast Ethernet NIC - Packet Scheduler Miniport
OutputQueueLength: 0
PacketsOutboundDiscarded: 0
PacketsOutboundErrors: 0
PacketsPersec: 150081
PacketsReceivedDiscarded: 0
PacketsReceivedErrors: 0
PacketsReceivedNonUnicastPersec: 46096
PacketsReceivedPersec: 100461
PacketsReceivedUnicastPersec: 54289
PacketsReceivedUnknown: 76
PacketsSentNonUnicastPersec: 540
PacketsSentPersec: 49620
PacketsSentUnicastPersec: 49080
Timestamp_Object: 0
Timestamp_PerfTime: 307990938968
Timestamp_Sys100NS: 127917316675144325
BytesReceivedPersec: 22831657
BytesSentPersec: 22831657
BytesTotalPersec: 45663314
Caption:
Description:
Frequency_Object: 0
Name: MS TCP Loopback interface
PacketsPersec: 157354
PacketsReceivedNonUnicastPersec: 0
PacketsReceivedPersec: 78677
PacketsReceivedUnicastPersec: 78677
PacketsReceivedUnknown: 0
PacketsSentNonUnicastPersec: 0
PacketsSentPersec: 78677
PacketsSentUnicastPersec: 78677
Timestamp_Object: 0
Message 7 of 9
(3,944 Views)
Message 8 of 9
(3,932 Views)
Good and simple solution !
________________________________________________________
Try to make everything Automatic
Message 9 of 9
(3,909 Views)
