Anyone ever implemented the SHBrowseForFolder in Shell32.dll from Labview 6.0.2 via a Lib Call Func
My customer feels the File Path Control is not as easy to use as the Browse for Folder box in Windows, I know I can call it from a library call function, but what do I need for parameters, as all I keep getting is a Labvview has preformed and illegal function and will be terminated error box from Windows.
Thanks for all I've learned on this list so far and in the future.
Rick
Message 1 of 13
(12,388 Views)
You don't say what version you are using. In LV6, the path control
has a built-in browse button that can be configured for selecting
files/folders, new/existing, etc.
For older versions of LV, make a browse Boolean and conditionally
execute the File Dialog node. It is located in the File I/O >>
Advanced section. It really isn't advanced to use and will be
much easier than calling a Windows DLL.
Greg McKaskle
Message 2 of 13
(12,387 Views)
Greg,
As stated in the question title, I use LV6.0.2. I have used the File Dialog in the past, and I agree that it is easy. This instance is not a matter of choice but 'customer' preference. I have found an activeX function to do as I want, but for my own understanding and knowledge, want to go throught the Windows API libraries, as it bypasses conversions, and goes directly to the op sys. I have the API .h files but don't understand what needs to be passed to the SBBrowseForFolder function, as it is stated that it needs a BrowseInfo structure, which I can pass, but not sure about other requirements or parameters, due to the error returned from WIN9X. Thanks for answering back my question though, as I think I have found a tough one, due to the lack of respons
es.
Rick
Message 3 of 13
(12,388 Views)
ue to the lack
> of responses.
Sorry about that. I missed the title. Apparently you are talking about
the SHBrowseForFolder function. If you haven't already, you might want
to read
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dncdev99/html/vc99c1.asp
You will need some additional WinAPI functions from the ftp site to get
the HWND for a VI to bring up the VI. I hope that gets you close enough.
Greg McKaskle
Message 4 of 13
(12,387 Views)
Hi Derick,
I have been trying to do exactly the same. For users, it is confusing
to be confronted with a dialog different to the standard windows
"Select Folder..." dialog.
It would be very nice if you could tell me what solution you have
found for this.
Rodrigo
Derick wrote in message news:<506500000005000000EA380000-993342863000@exchange.ni.com>...
> Greg,
> of responses.
> Rick
Message 5 of 13
(12,387 Views)
Rodrigo and all,
I have had several request for how I solved the Browse for Folder problem. Go to:
http://www.mwe.8m.com/vb/activex/
and download the pbffex.zip file, under the MW Browse For Folder Extensions ActiveX Control header. Unzip the file in your 'temp' folder and find the MPBFF.ocx file in that folder then copy it to your 'system' folder. Register the MPBFF.ocx with your system using regsvr32.exe. Then go into labview and insert an ActiveX container onto your front panel, and insert the MPBFF._MBFF control from the insert activeX object pulldown menu. You then have access to all of the properties and methods available to implement this component. I have attached a small VI, which I use to bring up the Browse for Folder
window.
Hope this helps you all out,
Rick
Message 6 of 13
(12,387 Views)
You have to create the Windows API BROWSEINFO type and set the Call Dynamic Link Library input type to 'Any'. Here is a VI that displays the Browse for Folder Box for Windows.
Message 7 of 13
(12,375 Views)
Whoops, didn't notice that you have Labview version 6.0.2. Sorry about that. Here is the correct VI for your Labview 6.0.2 and WIndows 98 system. Under Win98, most System dll's live in 'C:\Windows\System'. Under Win NT, 2000 and XP, they reside under 'C:\WIndows\System32'.
Message 8 of 13
(12,375 Views)
I like this dialog box, but it doesn't allow me to create a new folder.  Does anyone know how to add this functionality?  Also, is it possible to make this pop-up dialog box a modal window?
Thank you,
Steve
Message 9 of 13
(11,616 Views)
We did a version in the LAVA forums recently:
http://forums.lavag.org/index.php?showtopic=8678&start=0&p=32971&#entry32971
___________________
Try to take over the world!
Message 10 of 13
(11,613 Views)
