Anyone had experience using LabVIEW with IQFlex?
I am currently developing a tester that requires me to use IQFlex and LabVIEW. Sad to say, I don't know where to start.
Anyone knows how to use IQFlex (http://www.litepoint.com/)?
Does it have a set of DLLs/VIs/Libraries that I can call/control/manipulate with LabVIEW?
Help will be greatly appreciated.
P. Jack
Message 1 of 18
(7,434 Views)
It seems they have an API for Visual C/C++. Thus there are options to interface the box.
I think contacting Lite Point regarding their API will be a good step (get the API documentation) to take.
André (CLA, CLED)
Message 2 of 18
(7,420 Views)
Yeah, I think that's what is left for me to do. I tried searching for the so called IQV.dll but google doesn't have it.
Thanks anyway. I push my luck on lazy customer support again.
Message 3 of 18
(7,412 Views)
Hi P. Jack,
From this article it seems that "test scripts can be easily and quickly created using the API's DLL interface". You can then use LabVIEW to make DLL calls. I would suggest talking to LitePoint for more information on how to integrate the IQflex.
Message 4 of 18
(7,396 Views)
Hi Jack,
I also doing the project that using IQView tester to capture data. I get some related documents and api/dll files but somehow i not really know where i should start from. Any advice ??
Thanks and Regards,
Simon
Message 5 of 18
(7,239 Views)
To save time, we bought the software developed in LabVIEW from Litepoint. However, very difficult to use becauseof the lack of documentation and poor support.
Message 6 of 18
(7,228 Views)
They can make money by sell the program.  ")
I do receive some support doc and iqapi.dll & iqapi.h but i believe still lack of dll for calling main api object (iqapiHndl)/ header code.. i stuck ..
Is it the iqv.dll the main code??
Message 7 of 18
(7,223 Views)
Hi P.Jack,
I also do wifi programming with iqview intrument.
You can download the drivers for litepoint instruments as the following address;
http://www.litepoint.com/component/option,com_docman/task,cat_view/gid,142/Itemid,69/
However, this driver will generate a error after run sample, i don't find any solution for this issue until now. If you have any solution , please give me some information.
Roy
Message 8 of 18
(6,831 Views)
They do provide me with labview api, but end up take up their solution.
I do try with my version 1.3 & working fine with simple program.
regards,
Message 9 of 18
(6,818 Views)
Hi Simon,
   Could you please share the Labview API of IQflex to me, I am failed with downloading it from litepoint's website. Very appreciate your help!
My mail address is : coreychen8@hotmail.com,  also you can send to: chenzhongliang@oppo.com.
My phone is:+8613428503719;
Thanks for your help again !
Corey Chen
OPPO Corp
DongGuang China
Message 10 of 18
(6,250 Views)
