Anyone has experience to transfer data from LabVIEW to MATLAB via LAN
Hi, everyone, I have 3 PCs,
PC A : DAQ using LabVIEW collect data from sensors via serial ports
PC B : use MATLAB to do a signal(data from PC A) processing
PC C : use MATLAB to control the signal from PC B so that a robot can follow the command.
This 3 PCs has been connected via LAN, how can I transfer this real time data between this PCs,basically PC A need to trasfer data to PC B and PC B need to transfer data to PC C.
Thanks a lot
(4,162 Views)
hi there
well, create a dll written in LabVIEW that uses DataSocket to transfer the data over network, then use the dll in matlab to send/receive data. the LabVIEW - PC holds the datasocket server. this will work, but due to the LAN not in true real time!!
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(4,154 Views)
Hi, Chris, than you for your reply.
I am really novice in LabVIEW, I am not sure is that the same dll in LabVIEW and MATLAB, and basically how to generate a dll in LabVIEW?
Best wishes
Tao
(4,151 Views)
hello
it's not that difficult to do that:
first you create two vis "read" and "write". you can test the data transfer between two LV applications till you're sure all is working fine. then you create a dll which contains the read and write - vi as functions. these dll - functions are then called from MATLAB, while you can still use the vis in LabVIEW. the functionality of the dll - functions is identical with those of the vis. as a first step you can use the "Data Client" and "Data Server" vis from the examples list.
To create a dll in LabVIEW go to Tools->"Build Application or shared Library (Dll)" and then click "Help".
best regards
chris
Best regards
chris
(4,148 Views)
I guess this is more a MATLAB than a LabVIEW question, but maybe someone has succeeded doing what chrisger suggested in his post.
I have created a very simple VI CalculateSum.vi that adds two numbers, and used LabVIEW to compile a DLL. This appears to work, and I receive (among other files) CalculateSum.dll and CalculateSum.h.
When I try to load this into MATLAB, I get the following error message:
>> loadlibrary CaluclateSum.dll CalculateSum.h
Warning: Message from C preprocessor:
lcc preprocessor warning: r:\Rasmus\matlab\call LabVIEW\platdefines.h:117 r:\Rasmus\matlab\call LabVIEW\extcode.h:36 r:\Rasmus\matlab\call LabVIEW\CalculateSum.h:1 #error directive: "We don't know the Compiler"
lcc preprocessor warning: r:\Rasmus\matlab\call LabVIEW\platdefines.h:317 r:\Rasmus\matlab\call LabVIEW\extcode.h:36 r:\Rasmus\matlab\call LabVIEW\CalculateSum.h:1 #error directive:
> In loadlibrary at 268
Warning: Warnings messages were produced while parsing. Check the functions you
intend to use for correctness. Warning text can be viewed using:
[notfound,warnings]=loadlibrary(...)
> In loadlibrary at 277
??? There was an error loading the library "CaluclateSum.dll"
Error using ==> loaddefinedlibrary
The specified module could not be found.
I am using MATLAB R2007a and LabVIEW 8.20.
(3,953 Views)
