Anyone know why the vi niFgen Allocate Waveform.vi causes a second instance of LabVIEW to open in Windows
I have a large scale ATE written in LabVIEW 2011, using TestStand 2010 SP1 as the test executive that works just fine until the test sequence ends. For some reason when I close the completed executions from the Sequence Editor, a second instance of LabVIEW that gets launched when this vi executes stops responding, and I have to kill all LabVIEW processes to be able to run another execution.
I can't figure out why this vi is causing a second instance of LabVIEW to start, much less why it causes LabVIEW to hang.
Any ideas? I've included a screen capture of the implementation being used (the vi between the two breakpoints is when this second instance of LabVIEW launches)
(3,393 Views)
I'm not sure what else is going on but, you are wiring a waveform name out of that function to the Chanel name in of write waveform.  I'm surprised that isn't throughing an error since the Fgen probasbly does not have a "MyWaverorm" Chanel.
(3,281 Views)
No, it's wired from Waveform Name Out to Waveform Name, not Channel Name
(3,270 Views)
Really?
How?
(3,266 Views)
Thanks for clearing that up.  I would suggest updating NI-Fgen. There are a few known issues that "Might" be related.
(3,254 Views)
Therein lies the problem. This ATE is a PXI configuration, using the PXI-8106 Controller, but the system recently crashed and we did a recovery using the Acronis image. I can't for certain say what version of NI-FGEN this application was developed in originally. I agree with you, I think upgrading the development system is the way to go, but I have been requested by my boss to try and get it working with the IDE our documentation last showed it in.
Thanks for your suggestions though, appreciate it.
(3,243 Views)
