Anyone use a CIO-DAS-TC board for temp. measurements with Labview 6?
(2,560 Views)
Tony,
From what I understand, there are LabVIEW Drivers available for some ComputerBoards devices on their website. If they do not offer anything, you will have to obtain documentation on the drivers (DLLs) that come with the board so that you can use a Call Library Node in your LabVIEW VI to make calls directly to the driver.
The easiest thing to do (of course, I'm a bit biased) is to purchase a National Instruments Data Acquisition device to perform your temperature measurements. Our E Series devices are very easy to use and integrate seamlessly with LabVIEW through our free NI-DAQ driver software. Our low-cost E Series devices start at $395, so you can start building your temperature measurement system at a relatively low cost.
I hope these suggestions are helpf
ul. Please let me know if you have any other questions. Have a good day.
Sincerely,
Darren Nattinger
(2,560 Views)
