Anyone use netbook for LV before
Just wander if the netbook is good enough to support LV.
I want to run some LV runtime programming for DAQ with USB 5133 etc.
May I know if any one has the experience before, thanks.
(3,559 Views)
(3,553 Views)
If your netbook uses a Starter Edition (not Home or Pro) of Windows then you will run into trouble.
There is a work-around for Windows 7 Starter Edition but none for Vista Starter.
Battler.
Message Edited by battler. on 06-07-2010 01:54 AM
(3,545 Views)
Thanks, If I just install runtime engine for LV and DAQ, will it be any issues with the Starter.
(3,487 Views)
The run-time will not install onto Starter Edition Windows.  It is possible to apply the work-around (for an installer package) in the link for Windows 7 Starter.
I would not recommend you purchase PC with Starter Edition if you want to use LV.
(3,458 Views)
So the runtime is not able to be installed on the starter or it need manually installed on the starter.
(3,436 Views)
Accepted by topic author alex.
Windows 7 Starter = can be manually installed using work-around.
Vista Starter = RTE cannot be installed.
(3,413 Views)
