Anyway I can simulate a square wave in ultrasonic sensor
Where a person passes by for t period of time and the graph will show a pulse of the period. I’m trying to make the graph look like the sensor HC-SR04 when it detects some one passing by produce a 1 amplitude square wave against time.
(2,045 Views)
Hi ehanpaul,
mind to attach an image of the expected output signal?
(2,037 Views)
Are you trying to get a graph that looks like this? (Using a HC-SR04)
Or are you trying to simulate what the HC-SR04 actually outputs? (The ECHO Pin graph, below)
The amount of time that the ECHO Pin is HIGH is used to calculate a distance, based on the speed of sound (it's an Ultrasonic sensor, after all).
If you're trying to make the first graph, in LabVIEW, while using LabVIEW to control a HC-SR04, you'll need to
  1. decide "how close" the person needs to be,
  2. repeatedly test to see if the person is "there" or "not", and
  3. output a 1 to the graph if the person (or other object) is found. 0 if not.
If you've never used a HC-SR04 - keep in mind that their sensing capability is not robust - I've gotten a lot of failed reads while using them (where the sensor never saw the return signal, so it reported a distance further than it can reasonably detect).
-joeorbob
(2,014 Views)
