Anyway to programmatically add a page to Tab Control during VI execution?
I've read that this isn't possible. But those were old posts. I couldn't find anything more current so I'm hoping things have changed with Labview.
Basically, I just want to have a regular Tab Control with a boolean button, and upon it's press a new Tab Page is added to the Tab Control. That is all.
I read there is an Invoke Node for the Tab Control specified as Add Page, but it didn't seem to be there in my version of Labview.
Message 1 of 23
(7,449 Views)
You cannot add or remove pages of a tab control at runtime.  The pages are the owners of the controls and indicators placed on them.
You CAN, however, change the visibility of individual pages at runtime.  A tab control has a property called "Pages".  This is an array of page references.  Iterate over that array, perhaps looking for the "Page Label" property of interest, then use the "Page Visible" property (writing a Boolean) to get the runtime behavior you want.
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
Message 2 of 23
(7,437 Views)
You can use sub-panels to make it LOOK like you added a tab page. But please explain why you can not add the tag page at development time and just show/hide the tab to get at the same end.
Ben
Message 3 of 23
(7,426 Views)
Let me amplify my own earlier post:
You cannot add or remove pages of a tab control at runtime.  The pages are the owners of the controls and indicators placed on them.  Therefore, each page's existence is fixed at design time.
David Boyd
Sr. Test Engineer
Abbott Labs
Message 4 of 23
(7,405 Views)
And let me amplify David's point because it is the easiest and best solution provided you can establish what that "PAGE" will look like at development time. Simply hide/show as needed.
Have fun!
Ben
Message 5 of 23
(7,354 Views)
TabControls are enums, and enums cannot change during runtime.
Even if you could add a page during run time, the would not be a way to add anything on it.
If you turn on scripting, there is a method "Add page". But it doesn't work during run time (when the Vi is running), only during edit time. This might still be enough for you. You can script a control, and then start the VI it's on. But keep in mind that the program will never work in an executable before spending weeks on it.
I'd make a solution where there is a TabControl with enough pages. Show a hidden page whenever more are needed (within the maximum). When a page is selected, load the appropriate VI in a subpanel. You can make this look very (but not 100%) identical to a TabControl with dynamic pages.
Message 6 of 23
(7,345 Views)
how do we turn on scripting, can you please brief it...
Message 7 of 23
(7,246 Views)
Hi Priya,
don't you think you should read the LabVIEW help first?
Message 8 of 23
(7,238 Views)
If you don't know how to turn it on, it's save to say you don't want to turn it on.
Scripting is advanced stuff. It will only confuse you. It even confuses advanced users.
Also note that it will not solve your problem.
Message 9 of 23
(7,231 Views)
There is nothing wrong in knowing new things, without mistakes did anyone became an Expert..
Thanks Gerd
Message 10 of 23
(7,213 Views)
