Thanks JCC for detailed reply.
few issues in response of your reply that i would like to raise.
1)regarding point 6, let us first talk about only one source with amplitude 5(positive peak) , -7 (negative peak) and Frequency of 1.6Hz. in your example that you posted to me. i give 20000 periods and then i switch on stop watch to calculate the total time. the total time of the execution must be
12500 seconds.that means clearly when i run this VI.these 20,000 periods must take 12500 seconds to finish the execution. if i make pause in between and resume. it must pause and resume from the moment.that means the rest time and number of remaining periods must finish in the rest time. this tota
l time i calculated on the basis of frequency and and total number of periods.i am using the following formula(see attached VI please). now my question is that these numbers(20,000 in my case) of periods are not finishing their execution in corresponding time. why? am i using the wrong formula for frequency time conversion or some other reason. i hope i explain my question now.
2) regarding Ao start it is mentioned in the AO start help, when you set 0,it will continuosly generate the sine wave and when you set this parameter to 1, it will execute only once.that means by setting this parameter, you cannot interrupt it any more and when you set the parameter to 1 you can pause and resume. this is that i understand by setting parameter 0 or 1.
i am testing other examples that you send to me. as soon finish it i will acknowledge to you.
any way many thanks for your asisstance.
regards
