App Builder Issue -bug?
I do believe I've found a bug in LV6. Get the "Pages" property from a Tab
Control Property Node. This returns an array of refs to each page. Then
index the array at whatever to get a single page ref. Send this to a Property
node and read the property "CtlsOnPage". This returns an arry of control
refs found on the page. Send This array to the SizeOfArray function and
display the output. Throw some controls on the tab Control, and test to
see if the array CtlsOnPage size matches the number of actual controls found
on that page. When this vi is executed in the LV development environment
it works fine. However, when you try to incorporate it into an app using
the application builder the CtlsOnPage array never gets filled.
I would be interested to hear if anyone else has experienced this problem
and how they were able to fix it. ~Steve
(2,847 Views)
Steve,
I had the same problem with the pages property. I posted here about a week
or two ago. Title was something like "bug in LV6 tab control". NI responded
saying the bug is fixed in 6.0.1 but read the disclaimer first.
Jared.
Tab>Control Property Node. This returns an array of refs to each page.
Then>index the array at whatever to get a single page ref. Send this to
a Property>node and read the property "CtlsOnPage". This returns an arry
of control>refs found on the page. Send This array to the SizeOfArray function
and>display the output. Throw some controls on the tab Control, and test
to>see if the array CtlsOnPage size matches t
found>on that page. When this vi is executed in the LV development environment>it
works fine. However, when you try to incorporate it into an app using>the
application builder the CtlsOnPage array never gets filled. >>I would be
interested to hear if anyone else has experienced this problem>and how they
(2,847 Views)
