App Builder/Run Time Install Broke?
I have full up version of LabView 5.1.1, running on Win98.
I went through the Application Building Example on page 12 of the
Application Buidler release notes.
I then installed the sample app on another Win98 box. The application
installation went OK until it ran the install for the LabVIEW runtime.
Then I got the following error:
"Setup Initialization Error
Setup requires a different version of Windows. Check to make sure that
you are running Setup on the Windows platform for which it is intended.
Error 102."
I also get this same error if I run the LabVIEW runtime install
directly.
As I said, both machines are Win98. I'm stumped. Any ideas?
Mike T
(2,926 Views)
I am not sure if this is your exact problem but you might try it . I found
with the run time in 5.1 would not install properly . On the target machine
I did a runtime engine install from the APP builder disk , not from the 5.1
disk . Then things seem to get sorted out after that . I still haven't been
able to do a stand alone disk that installs the runtime engine and
application together yet. More for the lack of trying after I got a work
around (I hope?) . That was with win95 and 5.1 , not sure if the same sort
of thing will be true for 5.1.1 and win 98.
Hope that helps
"Mike T" wrote in message
news:3A32FB73.6C3C2E6A@postoffice.pacbell.net...
> Error 102."
> directly.
> Mike T
(2,926 Views)
