App. Builder generated not-working file at Win2000 *Unreganized CMD*
I'm new to LabVIEW, here's the question:
I wrote a simple VI, taking readings from HP 8563E spectrum analyzer, everything works fine on my winXP machine.
now I am trying to use Application Builder (ver 6.1) to generate stand-alone executive file, and that Applicatione.exe doesn't work on my Win2000 machine. On the spectrum analyzer there's an error message: 112 Unreganized Command.
I have attached the original vi and appliction.exe, please help. thank you.
p/s. I have installed run-time eingine.
(2,637 Views)
You didn't attach any of your subVIs. Do a Save with Options, choose Developement Distribution, and save everything into an LLB.
(2,637 Views)
Thanks for your reply..
now I have saved the VI as a .dll file, however, when I try to use Application Builder to make executive file, it pops up a menu asking me to add a top-level VI. I chose that .dll file and then there's another menu where I chose my original VI, then click the build button.
The built executive Application.exe works on my both lab PCs with LabVIEW installed, but doesnt work on other no-LabVIEW PCs.
Please help again. thanks.
(2,637 Views)
Hopefully you meant LLB and not DLL and I wanted you to post the LLB. The most common mistake when putting a LabVIEW exe on a new system is people assume that the exe file contains all of the GPIB and VISA drivers. Those have to be installed separately. You should have a driver disk with your GPIB card and after installation, check communication in MAX. If you have done all of that, it would be be nice to see the entire program.
(2,637 Views)
