App Builder place text file in same directory as EXE
Is there a way to have the App Builder place a text file in the same directory as the executable?
The App Builder always will put the file into the data subdirectory. I can't find a setting to change that.
(3,147 Views)
Manually delete "data":
George Zou
(3,138 Views)
But I also want to have some files go into data.
I will try that.
Thank you.
(3,130 Views)
Then create a new destination, and delete "New":
George Zou
(3,124 Views)
Are we talking about when building an executable or an installer?  Either way, it should only matter for the installer.
GCentral
(3,105 Views)
From memory:
  1. Add the file to the project.
  2. In the Source Files page, add the file to the build (you might not need this step)
  3. In the Source File Settings page, set the destination folder for that file to be that of the EXE.
___________________
Try to take over the world!
(3,073 Views)
