App builder and remote control
I want to build and distribute an executable, using Labview 6.1 - and I would like to use the remote panel control functionality. The end-users will not have Labview (other than the run-time engine), so they will have to use a browser to view/control the application remotely.
Is there anything else I need to package with the application executable (other than the run-time engine and the License manager)?
Can I use the Web publishing tool to create the HTML file for the remote front panel? Since the target machine will not have Labview, and will be running the compiled EXE file instead of a VI, how do I refer to the VI in the web tool?
Eg. I compile 'webapp.VI' into 'webapp.exe'. What URL should I use to connect to the appl
ication remotely, using a browser?
Thanks.
(3,085 Views)
gnm,
Please refer to KnowledgeBase 2IDDCHB9: Using Remote Panels with a LabVIEW Applications (EXE) for the information you are looking for.
Randy Hoskin
http://www.ni.com/ask
(3,085 Views)
