App builder missing file LV_RT_RT.msm
I have a source code file and a build file. When I try to build the application, it fails at the end stating that the following file is not found-Labview7.1/applibs/distkit/redist/modules/LV_RT_RT.msm. Does anyone know why it is looking for this file and why it is not being found?
(3,172 Views)
I don't have this file on my PC either.
My guess is that this may be a file that is only present if you have the LabVIEW "Real-Time Module" add on.
If you look in the build file on the "Installer Settings" tab "Advanced" button, do you find that the "Include.... LV RT Support" option is ticked?
I have no knowledge of the Real-Time Module add on, so that's as much as I can suggest.
Mark H.
Message Edited by Mark H on 06-22-2005 08:42 AM
(3,171 Views)
Hi Mark,
Yes the LV RT_Support item is checked, but it is grayed out so I cannot change it.
(3,164 Views)
Presumably you don't have this add on module then?
(3,161 Views)
Hi Mark,
No I do not have the module, but the service who created the application for me does. I was trying to use the build file they sent with the source code. I just remade the build file from NEW and now the RT link is not checked and the build worked.
Thanks for your help.
(3,158 Views)
