App builder with .inf file
I try to make deployment for a Labview app that use a .inf file to communicate with a printer. After the installation the printer don't work. I use a control for send data (USB0::0x0A5F::0x00A1::37J110900197::RAW)
The printer is Zebra, I made the .inf file with VISA driver wizard and on my computer works just fine. I try to install INF file but still not result.
It is a possibility to export settings from MAX? Or it is other possibility?
Thank you in advance.
(3,114 Views)
Accepted by topic author chiritab
Yes, you can export MAX settings. It is also an option when you create an installer. Your installer should also include NI-Visa.
(3,099 Views)
I exported MAX settings, like you tell me and after that I made update of the driver from Control Panel like is describe here http://www.ni.com/white-paper/4478/en/  and now works.
Thank you for support.
(3,051 Views)
