App failed. Error code 560290006. Bad input argument to function
I receive this error message when iam starting my application on the PDA "App failed. Error code 560290006. Bad input argument to function" (Build with the LabView PDA Module). When iam trying to debug the application it seems that it crashes before the debugger can connect to the application. There is no broken arrow in labview and i can compile it without any problems. When you need more information tell me 😉 How can i solve this problem?
(3,172 Views)
Hai m4st4p,
Search this forum with the keyword - "Bad input argument to function" .
You can get a couple of answers there. Post if still problem exists.
Mathan
(3,168 Views)
Oh i used this post to solve my problem: http://forums.ni.com/ni/board/message?board.id=170&message.id=113193&query.id=128403#M113193
Iam sorry to ask so fast befor i used the search function but thank you verry much to answer so fast 🙂
(3,161 Views)
Happy to hear that you worked it out.
And mainly thanks for the post stating the link with which you got figured out your problem.
This will help the other people searching.
Mathan
(3,159 Views)
