App not starting in windows7
Hi i have a app that runs in xp    with out any problem , but when i try to run  the same app in windows 7  it does not run see the error
( the daq board is there i see it with measurement and automation test ) in windows 7 starter
So what is going on i have no  idea myselve
App is made with labview  8.6
windows is version is windows 7 starter
Message Edited by cees10 on 04-03-2010 01:40 PM
(2,846 Views)
There are no guarantees that an application developed using LV 8.6 will run under Win7.  Only LV2009 applications are intended for Win7.
There is still a chance that a LV8.6 app will run.  What does MAX show for your daq device under Win7?
(2,836 Views)
And I don't think the starter version is a well supported. You might need the full version of windows 7.
(2,833 Views)
As you can see i can work with  the device    under windows7  under Max  ,manual i can move the switches it works also
ONLY te program under 8.6 does not work
(2,822 Views)
