AppBuilder compile error message
When the application build process fails the message you get from the application builder is not always very helpful.
There's a lot of posts on the forums and in the knowledge base about obscure build error messages and what to do to fix them.
I've been able to isolate a simple case in which - I think - it's reasonable to expect a more accurate build error message from the App Builder. I've reported it to NI Tech support as a bug.
I'm quite sure some would argue it's not a bug, to me it is.
What do you think?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,962 Views)
For the record, NI acknowledged the bug and created a CAR #1487369.
Epictetus
Antoine Chalons
(3,788 Views)
Sometimes it feels like Labview runs a RNG and throws it out as an error number.
Very rarely have i gotten an error number that actually helped me in search for solution.
(3,781 Views)
If you're talking about build errors, I agree.  In general, though, I've found LV errors to be mostly useful.
Bill
CLD
(Mid-Level minion.)
(3,765 Views)
