Append each bit to the binary number (Not Array Indicator)
Hi All
If i have the 8 Number control. Each Control represent each bit.
i.e. 0th control bit="1", 1th control bit="0", other bit = "0"....7th control bit ="1".
How to output the 1 binary number indicator. -->10000001
Best Regards,
Steve
(3,253 Views)
I had solved it.
i use true/false case to multiply each bit interial.
i.e. For 8 th bit. If =0, output to 0, if =1 (i.e not equal to 0), output 10000000
      For 7 th bit. If =0, output to 0, if =1 (i.e not equal to 0), output 1000000
Final, use "OR" function to build into 1 binary number.
Please refer the attached graph.
Anyway, have the other fast way to do this result??
Steve
(3,249 Views)
Hi Steve SO,
you can also use binary controls and build an array of that. It is the same result without using case structures.
Mike
(3,243 Views)
