Append report text.vi
Hi all,
Is there a way to amend this vi so that it will centre text or perhaps invent a new one?
I would greatly appreciate it as i need to centre alot of text on the page i print and can find no easy way to do it
Its just a standard report not an excel or word
Mike
Message Edited by MikeW1973 on 03-11-2008 12:08 PM
(3,347 Views)
You can certainly open the Append Report Text vi and modify it as you please.  You should rename it though.  If you ever re-install the report generation toolkit, it would overwrite your changes if you didn't rename it.  However, I don't know how you would go about centering the lines you want to append.  Perhaps counting the number of characters in the line to determine the number of blank spaces needed to be inserted in order to center the line.
- tbob
Inventor of the WORM Global
(3,334 Views)
Counting the number of characters and the space only works if you are using a monospace font. The default is the application font, which is a porportional space font. That process generally does not work too well.
(3,331 Views)
