Append strings to file
How do i modify "write characters to file.vi" such that every time i append a new string to the same file, it will start at a new line?
There is this parameter in the vi that is called "convert eol"? Read the help file but could not figure out what is a end of line marker. Please help.
Thanks.
(3,016 Views)
the easiest way is to concatenate EOL symbol with your string and then write this new string to the file.
So you will write something like
EOL"your string". (or "/nyour string" in codes)
EOL symbol and "Concatenate strings.vi" you can find in "Functions/String/..."
Good luck.
Oleg Chutko.
(3,016 Views)
