Append successive Letters onto the end of a string
I'm trying to create a simple subVI that appends the next letter (A,B,etc) to a string, and removes the previous one if possible.
Input: a string. The base string will always consist of a series of letters followed by a series of numbers, but the subVI may be called multiple times
I don't know how to check if the last position in the string is a 'letter' as opposed to a 'number', and I'm not sure how to increment a letter in LabVIEW.
This is the first coding situation I've reached where the solution seems more obvious in C++ or Java than in LabVIEW.
(3,111 Views)
It might be easier to switch the string into byte arrays. Add one to the last character.
(3,105 Views)
Thank you! It increments the letter, which is what I needed. I can use Lexical Class on the last digit of the string and check if it is equal to 4 to find out if there is already an uppercase letter on the end.
(3,081 Views)
