Append table in SubVI
I want to have a different table for every subVI where each column is a single channel and there are 3 channels per subVI. Right now the table I have built into my subVI holds data for every channel(all 18) so every table looks the exact same. The Express VI I added in has the result I want but I didn't know if there was a way to add it into my subVI so I can include it with the report.(I put labels on all the functions involved).
Thank You!
(4,127 Views)
I would also like the data type to be 2D
(4,113 Views)
Accepted by topic author Amanda_Kay
'Get Array Subset' should easy enough get you 3 columns at a time.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,100 Views)
