Appending a 1D array (from switch) to a 2D array
This question I know should be very easy, but it doesn't seem to be working.
I have a 2D array, imported from a *.csv file, and a 1D array controlled by a switch.  I would like to concatenate the 1D (column) array to the end (last column) of the 2D array.  I am using the "Insert Into Array" VI, but I am not getting any output.  Can anyone help me?
I am attaching the my VI and *.csv file if it helps.
Thank you,
Amal Patel
(2,820 Views)
Duplicate post.
In the duplicate post you created you attached the VIs. Don't do this. Just reply to this thread and attach your VIs to the new message.
(2,812 Views)
