Appending a table with periodic array data
I am working on an application where I am reading in several variables through the serial port. The variables come in as a string of 4 integers delimitated with a [space] and ended with a carriage return. The loop then outputs the data as a single string and then is separated into its separate parts. I would like this data (currently 4 integers) to be appended to a table of 4 columns and n rows (n should increment by 1 each time data is raceived as the new data is appended). I have looked at several examples of "similar" things but I am having a difficult time getting it to work. Please see the attached file. Thank you much in advance!
Gregory Osenbach
(2,726 Views)
Use the "insert into array function" and place it in a case structure in the main loop. Every time the aquisition loop sees a carriage return (indicating data aquisition complete), append your new data to the array. Hope the attached example is what youre looking for.
(2,726 Views)
Yes, That helps very much. Thank you.
Gregory Osenbach
(2,726 Views)
