Appending data to a string control and the cursor should be at the end
hi,
     my requirement is to append data to a string control continously and the cursor should be at the end of the string control. I am using a string control to give the status of a test that is running continously. How can i use it to give the status. It is similar to  a chat window application or a hyperterminal window which gives the status.
Jay
(2,450 Views)
Hi Jay,
you can use a loop with shift registers. Create your string there and write it to your string indicator. To see the last line you can use the scrollposition property.
Hope it helps.
Mike
(2,421 Views)
