Appending new VI to a myRio project
I have a code in a myRio project (name it "MYVI"), and I need to add another project (let`s name it "CAMVI") into it.
There are two scenarios with different errors:
1- I add the MYVI to CAMVI, but the myrio option does not show up and errors that expression is not in this VI.
2- I add the CAMVI to MYVI, the error says "failed to load the library", the error message is attached.
does anyone have an idea about it?
(2,088 Views)
Hi saeed,
the error message is attached. does anyone have an idea about it?
Did you follow the recommendation given in this error message?
Use MAX to install VISION/IMAQ on your myRIO…
(2,048 Views)
