Application Build Error 1003
Hi
I have a project and when I try and build it in to an Application I get an error saying a VI in broken and of course it is not. Below is the error details:
"Error 1003 occurred at AB_Targetfile.lvclass:Open_Top_Level_VIs.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller"
I have located the problem down to a vi called Runtest in a packed library. Analysing the Main.vi also highlights the same problem. If I dont include this Runtest.vi in the Main.vi that I build my application from then it builds fine.
I made the packed library myself so I went in to the packed library project and made a application that included the Runtest.vi. This builds fine.
Any suggestions?
Using Labview 2011.0.1f2 (32bit)
Message 1 of 14
(8,994 Views)
What is the problem with the RunTest VI? Does it has broken arrow or you found something else?
Message 2 of 14
(8,990 Views)
No the RunTest.vi is not broken and runs fine using it in its own project or when built in to a packed library. It is only when I try and build an application that contains the RunTest.vi in a packed library that I get the problem.
Could there be a dependency or link that is broken then RunTest.vi is built in to a packed library and then used in the other application?
Message 3 of 14
(8,986 Views)
This may sound stupid but i recently had a similar problem and i solved it by running labview in compatibility mode xp!
No idea why but thta solved it...
Message 4 of 14
(8,984 Views)
I saw your post. How do you run it in xp mode?
Message 5 of 14
(8,980 Views)
Right click on LabVIEW exe and select properties/settings (i am german and use windows in german...)
Select compatibility and then chosse run in XP mode
Message 6 of 14
(8,971 Views)
Instead of finding a way to run try to find the root cause. I see the error is occurred in the Open_Top_level_VIs, So I guess there might be conflict issues also. Do you have any conflict in your project?
When you say you the RunTest is working fine when it is in its own project, how are you calling it in your code? Do you see some VIs in your dependencies list?
Message 7 of 14
(8,963 Views)
I tried running it in compatability mode for windows xp SP2 and xp SP3 but that has not worked.
Message 8 of 14
(8,962 Views)
Is the error message changing or do you always have the same error?
Message 9 of 14
(8,952 Views)
I dont have any conflicts in the project.
I agree with finding the root cause there must be a hidden dependency some where. I am going to do a big restructure of the files today and I'll get back to the post  tomorrow if I still have problems. Hopefuly the resturcture might sort the dependencies out. The Runtest controls some hardware so I am going to pull all the hardware code out and make instruments / drivers for them. I have been including some of the hardware code within the project so I will remove them from the project and have them as dependecies instead.
Thanks for both of your help so far.
Message 10 of 14
(8,935 Views)
