08-27-2007 10:03 AM
08-28-2007 10:09 AM
08-28-2007 12:30 PM
08-29-2007 09:29 AM
08-29-2007 11:45 AM
08-29-2007 11:46 AM
08-29-2007 01:14 PM
09-06-2007 11:47 AM
Hello Marc,
I used your project files and removed the Application and Installer that you had built and rebuilt them. I wasn't able to reproduce the issue with the renaming/moving of the parse.dll and Help.html files but I did see that I was unable to register the DLL. The "Register COM" checkbox was always grayed out whether the file was located in the data folder or in the top level directory. I'll keep you posted.
Clint M
09-06-2007 12:16 PM
09-13-2007 05:59 PM
Hi Marc,
It looks like this is an issue in LabVIEW 8.5. I have sent a Corrective Action Request (ID: 4D3CTJLV) to R&D so that they can investigate this issue further. The current workarounds are:
1) Build an installer which runs a bat file after installing to register your COM object (see the LabVIEW help for further information) or
2) Use System Exec.vi to register the DLL in the code.
You are currently using System Exec.vi, and unfortunately it looks like you might have to keep using this for right now. Thanks for letting us know and sorry for the inconvenience.
Clint M
