Application Builder Question: how to install several applications in the same computer?
I have two LabView applications and its installers, all of them generated with the aplication builder. Both works fine: I can install them in several computers without LabView. But when I try to install both in the same computer, the result is that I only have the last application I've just installed. I want to get the two applications installed at the same time in the computer. Is it possible? Anyone can help me?. I'm using LabView 2009 SP1
Thanks in advance
Message 1 of 15
(3,425 Views)
Double-check your BUILD Specs for both target apps.
Make sure the TARGET FILE NAME is different.
Steve Bird
Culverson.com
LinkedIn
Message 2 of 15
(3,423 Views)
Hi Steve.
Thanks for your repply, but the Target File Name are different. Furthermore, I am trying to install them in different folders, both inside Program Files; with different names,...
Message 3 of 15
(3,420 Views)
If I understand you correctly:
from scratch, you install A, and you get A.exe, where you expect it.
from scratch, you install B, and you get B.exe, where you expect it.
If you then install A (when B has already been installed), then B.exe goes away?
Is that what's happening?
Steve Bird
Culverson.com
LinkedIn
Message 4 of 15
(3,417 Views)
Exactly that. I'm triyng with several options in the Application and Installer builder, but it seems it does not work
Message 5 of 15
(3,412 Views)
It works quite well. We have installed over a dozen different applications on the same computer. I suspect you have something configured incorrectly in your installers and possibily the builder itself. We would need to see those to see what is not correct. One possibity is that your builds are generating the same GUID for the applications. Therefore even though the names are different the installer thinks they are the same thing.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 15
(3,410 Views)
There's nothing in principle that prevents you from installing 2 or more apps, it's very possible.
Try installing them someplace OTHER than "Program Files".  Perhaps Windows is being "helpful" or "protective".
Steve Bird
Culverson.com
LinkedIn
Message 7 of 15
(3,406 Views)
Thanks. Is it possible to know the GUD asigned to the app? I've created the second app form the first one; and only modify the VI's source code and the names and destionations in the builder.
Message 8 of 15
(3,405 Views)
I'll try and tell you here
Message 9 of 15
(3,404 Views)
I've just try. It doesn't work
Message 10 of 15
(3,402 Views)
