Application Builder Source File Settings
I've recently upgraded to the full version of LV 8.2 and purchased the license for the application builder.  On the "Source File Settings" tab I would like the program to not run when opened, and not to show the tool or scroll bars.  Although I've tried several different check, uncheck combination my final .exe alwyas has these options enabled.  I checked my original VI properties and it is not set to run at start up.  I'm not even sure what the "Value" highlight section is for.  My program is a simple temperature monitor and aquisition program with no sub-vi's.  What am I overlooking?
Thanks.
LabVIEW 2016 - Windows 7
CLAD
(3,049 Views)
Hi MeCoOp,
look at this post
Ton
My LabVIEW Ideas
(3,043 Views)
That did it!!  Thanks for your help...now to build an installer Smiley Wink.....
CLAD
(3,028 Views)
