Application Builder does not work with Eurotherm 24XX-Driver
I have to programm the software for a new teststation including some Eurotherm 2216 and a Keithley 2700-instrument in Labview 8.0.
Labview offers drivers for the Keithley 2700 instrument and a driver for the Eurotherm 24XX-series that works well with the Eurotherm 2216.
But if I try to build an application with the application builder, I receive an error message:
The following files include incorrect links to help files. Open the files and correct the links:
C:\Programme\National Instruments\LabVIEW 8.0\instr.lib\ET24XX\_ET24XX.llb\ET24XX Utility Multiple Write To Registers - Floating Point.vi
I checked this file - there are no links to help files included.
I receive a similar error message for the Keithley-Driver.
I attached the file making the problem.
Would be fine, if someone could help me.
(2,762 Views)
I had the same error with my application after I transferred it from LV7 to LV8. I used some external files for documentation of the VI's. LV8 does not find these files anymore (old and new location) Open the VI and add the help file again.
Hope this helps.
(2,742 Views)
