Application Builder- how to get rid of Saving changes to project after build?
Hi
I'm using LabView for Continuous Integration project with Jenkins. I have a vi that runs test cases and makes build of the project, then Jenkins reads information about the results.
After successfull build, there is a warning that I have unsaved changes in project that I wanted to build. This message is holding labview from closing and jenkins from showing results
I found here the information about this warning in first "Note"
http://ftp.datx.com/Public/DataAcq/LV-Link/LVLinkWebHelp/Building_and_Distributing_an_Application.ht...
How to get rid of this warning, or save the changes automatically, so that I don't have to click on "Save" after every build?
Karol
(2,625 Views)
Accepted by topic author karolek
First of all, you don't want to get rid of this warning. It's this save that makes the auto-incrementing version number work. LV has to save the new version number into the project.
Yes, you can do a save. Somewhere there needs to be LV code that programmatically performs the build. At the end of this process you need to save the project. There is a project method to do this.
I wrote a little program for myself to open a project, perform the selected builds and copy the resulting installer to a thumb drive.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,593 Views)
Exactly!
I had to open project to get reference number (using invoke App->Project open), then after building, invoke Project-> Save and close reference
Thank you!
K
(2,574 Views)
