10-23-2006 02:53 PM
10-23-2006 04:04 PM
Have you tried to set the properties of the Main VI being built? It should default to these settings but you can still change them. See attached picture from 8.20
10-23-2006 04:07 PM
10-23-2006 04:27 PM
10-23-2006 05:20 PM
10-24-2006 08:51 PM
Joseph:
I was able to verify what you mentionned in your first post, not being able to remove the abort button from the application builder is unexpected behavior and I thank you the feedback.
I have reported this issue to R&D so that they can investigate it further. I cannot, at this point, give you a timeline of when I will have something constructive to report on this issue. I will definitelty keep you posted on any workaround / development on this issue.
Again thank you for your feedback. It is through feedback such as this that we can make LabVIEW an even better product.
Rudi N.
Application Engineer
