Application Builder skip sub vi
I created an exe, for some reason the exe does not execute some (many) of my sub vi
there is no error pop up, any explanation and how to solve it?
(3,444 Views)
Accepted by topic author coloredsound
Hi sound,
Ok.
How do you notice it doesn't execute your VIs?
In executables there are seldom error pop ups…
Check for errors in your VI(s).
Generic answer on your generic question:
Attach VI(s) to allow us to inspect your code. This will give us (atleast) a chance to provide more detailed comments on possible problems! Otherwise you should do some debugging on your own…
(3,434 Views)
Did you try making the dll as always included in Source File tab in Build Properties and try?
-Provide more info on what popup and error.
uday
(3,432 Views)
Hello GerdW,
Thank you for your reply
I do aware that i will get generic answer
anyway your answer clear up something
i will mark solution after i fully test the code
(3,291 Views)
