Application Builder
LabVIEW 2014 Application Builder "Installer" builds without error but "Volume\Bin" files have changed from previous version of LabVIEW. I have attached a PDF describing the differences. This change has caused a problem with the Windows installer  program that I have used previously, "Advanced Installer". How can I get LabVIEW 2014 Application Builder to generate files like the previous LabVIEW versions?
(3,758 Views)
You can not configure Application builder behaviour.
How was Advanced Installer configured for previous LV version? It does not say "supports installing LabVIEW volumes". You feed in the list of msi files with paths into its config file.
Get a list of products Application builder generates (scan folders or parse setip.ini file) and describe them in Advanced Installer.
(3,744 Views)
Thank you. Knowing that I did not somehow change the LV App Builder configuration (as you say it can't be done) is reassuring. I believe that Advanced Installer is caching some old references and using those during the build. Stay tuned....
(3,730 Views)
