Application Command Line Arguments get file path from windows explorer
I'm trying to open a file with my labview application .exe, so I thought that windows was sending the file path double clicked in explorer as an argument but all I get is the filename of my exe.
Does anyone know how to setup windows or the application to get the filepath double-clicked from explorer which the file extension has been already associated to my exe?
Thanks!
(4,273 Views)
Accepted by topic author JimChretz
I am not sure I understand but I think you want your Labview program to open another file, like a perimeter file?
Have three basic choices.
Hardcode the path with file name into your program https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/constants/path.html
Use the file open vi and have the user select the file to open https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/express/express-input/filedialogblo...
Write your progam to accept a commandline argument https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHdICAW&l=en-US
=== Engineer Ambiguously ===
(4,266 Views)
Hello!
the part I didn't know about was the "Pass all command line arguments to application" to activate in the builder, once done, it all works.
Thanks a lot!
(4,246 Views)
