Application EXE from vi error win32
I did all you tell me,
and it works ( application and installer work )
but i can't find serial port ( i already install driver of the card i want to connect with labview)
i clic refresh but nothing show up.
( if you want to know what  card, it' arduino uno )
Thank you
Message 11 of 13
(692 Views)
khga 123,
Thanks for posting your questions. Since, this is a new and different topic if you could repost this in the correct form category
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/bd-p/140
Also, when you post, if you could please include a little more detail.
Where can you not find serial port?         (Screen shots can sometimes be beneficial)
What refresh button are you pushing?
Are you using the arduino toolkit?
Matthew
Application Engineer
Message 12 of 13
(654 Views)
Thank you
That uno most likely exposes the serial port as a virtual Com port requiring the FTDI Driver (See Here to download the driver)  You often have to run that silly installer TWICE to actually install the darn driver (Don't ask me why but- I've found out the hard way)
Message 13 of 13
(645 Views)
