Application Error LV6.02
After running for a while (minutes) my application crashes with an
Application Error:
The instruction at "0x00000000" referenced memory at "0x00000000". The
memory could not be "read".
Anyone got an idea what is causing this error?
Gr,
Frank
(2,926 Views)
Not if you don't give some more information to work with. It looks like a null-pointer exception of some kind. If you are calling any external code using the CIN and related functions, most likely the problem is there.
It would be best if you post a small example program that exhibits this behaviour so that we can have a look. (Trimming down your program and keeping the problem in it will also help you yourself to find out where the problem is)
(2,926 Views)
I encountered the same error message when launching MAX on a W2K machine.
The system administator gave me more rights and the problem was solved.
Although the error message is the same, I really don't know if the cause is the same. But if you are running W2K and have only limited rights you can at least give it a try...
(2,926 Views)
