Application Web Server crashes cRIO
I have found that including the NI Application Web Server 1.1 in the installed software list of a cRIO will cause a hard crash and hang.
I am including the MAX report of the software that I am running.  Is this some known conflict?
    • Software
      • NI System Configuration network support 1.1.6
      • NI Web-based Configuration and Monitoring 1.0.1
      • NI-1588 Configuration 1.0.0
      • NI-Industrial Communications for EtherCAT 2.1.0
      • NI-RIO 3.6.0 with NI Scan Engine support - January 2011
        • DataSocket for LabVIEW Real-Time 4.8.2
        • EPICS Server I/O Server 1.7.1
        • HTTP Client 1.1.1
        • HTTP Client with SSL Support 1.1.1
        • LabVIEW Real-Time 10.0.1
          • LabVIEW PID and Fuzzy Logic Toolkit 10.0.0
          • Language Support for Japanese
        • Language Support for LabVIEW RT 1.0.0.3
        • Modbus I/O Server 1.7.1
        • Network Streams 1.0.1
        • Network Variable Engine 1.7.1
        • NI Scan Engine 2.0
        • NI System Configuration 1.1.3
        • NI-RIO 3.6.0
        • NI-RIO IO Scan 1.6.0
        • NI-Serial RT 3.7.0
        • NI-VISA 5.0
          • NI-VISA ENET-ASRL Passport
          • NI-VISA ENET Passport
          • NI-VISA PXI Passport
          • NI-VISA USB Passport
          • NI-VISA Remote Passport
          • NI-VISA Server 5.0
        • NI-Watchdog 5.0.0
        • Remote Panel Server for LabVIEW RT 3.1.0
        • Run-Time Engine for Web Services 3.1.0
        • SSL Support for LabVIEW RT 3.1.0
        • System State Publisher 2.0.0
        • Variable Client Support for LabVIEW RT 1.7.1
      • NI-TimeSync 1.1.0
      • NI-TimeSync Plugin for Software-Based 1588 1.1.0
(3,474 Views)
Hi sachsm,
What cRIO model are you using and when are you seeing the crash? Is it during the install process, right after install or when you are trying to run your program?
<Brian A | Applications Engineering | National Instruments>
(3,432 Views)
I was recently notified that this problem has been reproduced by NI AE.  I will post an update when I get more information...
I am running on a cRIO 9076 + 9144 etherCAT.  The crash occurs after the rtstartup.exe is running, around 30 seconds into it and then
a sudden hang with no console errors or error log output.  The system restarts after another 30s and the cycle repeats.
(3,429 Views)
Glad to hear you were notified by an AE that the problem has been reproduced.  If possible, please post what you hear from them as I'm sure other users with the same problem will want to hear the solution.
Thanks!
(3,415 Views)
