Application buiding with Install Shield and LabView 7*
is it possible to create a application(*.exe) with the Install Shield Programm?
How could I include the Run-Time-Modul?
Thank you for your help.
CD
(2,863 Views)
Yes i beleive you can. Tell install shield to include
applibs\distkit\redist\modules\lvruntime.msm
AR
(2,863 Views)
yes of course.
It is possible, to include the Run Time Engine in the installer.
You use the application builder, click to the "installer settings" and set the flag: "create installer".
After this press the buttom "Advanced".
Now you can do different settings, which you required.
Some of them, is the option "LabVIEW Run Time Engine".
The Run Time Engine will be included everytime as default value.
Hope this helps,
best regards.
Sebastian N.
NI Germany
(2,863 Views)
