Application builder 7.0 – How can I make my front panel size the entire screen
Then I use Labview application builder 7.0 to convert my application to a *.exe file but I can’t make the front panel size the entire screen. I will always have the Windows XP menu bar in my window. I have tried change the VI properties window appearance and window size settings but I can’t get rid of the menu bar.
Magnus
(2,493 Views)
Have you tried auto-hiding the taskbar?
Right click on it and select properties.
Select auto-hide taskbar. Then it will free that space.
Hope this helps,
Paulo
(2,490 Views)
